2天前
查看: 2615|回复: 2
[推荐] 西门子发布最新的Solid Edge ST2 补丁MP12
发表于 2011-3-8 08:06:22 | 显示全部楼层 |阅读模式 来自: 中国广东江门
Dear Solid Edge Customer:
' i- d; j6 U- I9 R. B8 |
We are pleased to inform you that Maintenance Pack 12 (MP12) for Solid Edge ST2 is now available for download on the GTAC FTP server.
7 G, a8 F+ u2 M9 j9 G+ p
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
! H3 `# q/ i2 O- U
Sincerely,
/ M* H9 {% Q$ @/ ^8 P) F; R2 C$ y
The Solid Edge Team
) c% o* q# `' g9 w2 i+ z' ?
5 G" [$ y( ?  Y, N6 r1 u
Download Location:
; d2 L1 u% ^* B- I
3 Q$ T7 G( c$ f8 g: R8 G
Solid Edge (Maintenance Pack)
2 B" i% x; g0 U6 x
% T5 S! T6 t6 Q" _, d8 j4 ^5 W
Solid Edge Insight Connect (Maintenance Pack)
5 X8 i+ t- V+ G; Y& A: \
# W" }# J, `# L& o
Solid Edge Viewer (Maintenance Pack)
  D6 l* @6 X; h2 d
- l' Z1 c# h5 x4 h  p" B% a
Solid Edge Mold Tooling (Maintenance Pack)
% ?% O7 L) Z' O# d9 g) Z
: ^7 P2 s( _" E: b4 x" v
Solid Edge Insight Server WSS 2.0 (Maintenance Pack)
3 q' g, ^8 x9 v6 j8 n" U
" Q: P( T, u) V3 p
Solid Edge Insight Server WSS 3.0 (Maintenance Pack)
/ p% Z; O6 |5 {3 b' l0 ?* ^( s% Z$ r
6 I" x' d6 O2 J' X
Solid Edge Embedded Client (Maintenance Pack)
  ~' x3 j  I3 h' u
* m7 {9 L0 f. O: T" u1 @7 b
Solid Edge Embedded Client Administrator (full install)
& U9 F; {9 C0 c# u1 }0 Z- q6 U$ ?1 }9 p# B# u+ Z1 \
( x9 n6 v/ ?3 J' I6 z% D
Installation:
2 v( Q+ H/ S" k" L
+ Y3 V2 e9 X3 _2 {
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on setup.exe to install the Maintenance Pack.
9 h& t! [  p% t" K1 Q9 G
2 U8 F, J  R! y+ d3 O( z! A. u
E-mail Notification:
# T+ [7 d% v7 l  b' D- f% d* B
  f4 Z; W0 ^; c  R0 f1 J  \) Y
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
" o& b5 l; N. j
5 ?8 T: y3 i" Y- y9 X
This Maintenance Pack addresses the following PRs:
; x5 R( Y* B. S/ k, H, {; j
1 H! C5 k5 r3 y7 C. B! H. p. v9 f
===API===
' n! s/ ~9 ~( Z
PR 1826916: PropAuto.dll library in SE ST2 MP11 returns wrong string values
" w. E  ]/ C: Q
=====Assembly=====
- B5 g) w, ?7 r. M( M# s6 l4 @
PR 1824462: Fixed crashes identified in the crashlog analyzer
4 @1 A/ \) C' o& i, C
PR 6464369: Fixed crashes identified in the crashlog analyzer
7 k3 F" `: n9 t4 Y
PR 6474039: Fixed crashes identified in the crashlog analyzer
9 E7 z0 }; L2 c* ?+ e
PR 1819591: Assembly aborts when creating relationships
" a. r  p: Q5 Q" H" O0 q! Y
=====Draft=====
. p! x0 @# u1 b
PR 2162210: Thread Display Mode changes value when Apply button is clicked on other property pages
9 b. G% O! l- J2 c5 M
PR 6327121: Fixed an abort on close if dim tracker has been run and something remained in the select set
! L5 u" {9 W5 z
=====Part/Profile/Sheet Metal=====
# {# g- r! F; m: f: ?& [( H( y( b
PR 1824158: Invalid relationships created when Relationship Colors is on
# y. b  P. A" T
PR 6417621: Curve by table does not work with Office Pro 2010 (32 bit)
7 |2 g' i" b! }: t
PR 6475818: Send Mail & Crashlog tracking failing under Lotus Notes
. P. D, c4 A: X4 ?% c- u- y
PR 6466294: MP11 will not install on a 64bit Windows 7 machine that has MP10
* w* h' s* f4 O! q2 N8 v
===== Solid Edge Embedded Client=====
' @3 b6 U5 I8 W! b
PR 6401679: Save As Draft puts the part & JT data under the old item revision
) S6 F! D" P' b3 j
PR 6458567: Crashing during Save As on large assemblies
7 `% |% w; t2 e" Q0 `6 c
PR 1795398: QAT customization causing uncontrolled memory growth
发表于 2011-3-8 08:25:39 | 显示全部楼层 来自: 中国北京
ST2的补丁已经用不上了
发表于 2011-3-8 15:23:07 | 显示全部楼层 来自: 中国安徽六安
呵呵。你用ST3当然就用不到ST2的了
