求助:有偿设计两维曲线变成3维图形(13701297901王先生)
) O5 f& Z0 L" R* ]9 P , @8 d9 x* O% i. _+ G
两维:距离(或者叫厚度、高,每个都是固定的:0.18Cm);同心圆横截面积(可提供几个特定距离点或者每一个点的横截面积组数据)。
3 ?. r7 F" T7 |3 s/ w" g: D j% S# R# W( K
(以下是每个同心圆的横截面积值,高都为0.18cm)& h7 x4 e& ?* Q/ F
0.0547384313% j3 ^) e6 O' `: t- }
0.9758905991& o; a: u- D& G" Z
0.9087750625* Z5 l3 L0 Q- {! @
0.8833772966. C7 s" s5 O- o9 S
0.8945792372
" a* v+ E2 z2 p, \2 f 0.9253024879
, n0 {/ L7 H3 V' R1 b+ I 0.9285757433
* q% E, ?/ X4 q" B6 a. l1 d 0.8722903768" g: o' C3 Z, \3 M% p4 \
0.76439033247 N: C; V9 t5 q9 }& F
0.6426339493* ?1 ?! r9 f: e |4 O- E; q
0.5522512299
k# L2 t# w+ J/ r 0.1071543023
9 g$ S/ Z- R; |1 a# w 0.5152965651
4 t; O& i% u. s9 m, b 0.5680789063/ h) O% g9 r, l- {
0.6566464065+ M" W6 V& A d# }' j, T
0.7603061474( H7 v, C$ P% k: B" [. n
0.8607047648
& F/ Z+ x$ Y& ~, N/ z6 u 0.9498151130
) b" n9 x: o& b' @ M 1.0231859785
0 z7 n' ] w2 J+ _1 H* ^, F" D 1.0945783232; b* H4 e# e' [9 h
1.1533797502( D0 h5 \6 V& x( J9 B
1.1941300848% L% E- C6 |" C( V) N! r+ ^' y
1.1969346456; M* i( X( E; }- F! u. [/ u
1.1699235014
$ v4 A4 V. s- e- x/ k1 B1 B 1.1311518135# T. S4 o1 B W" M
1.1086286240# c8 g5 Y" g) x5 d0 w
1.1330743513" k: p2 ^" | \) E' N
1.21599640468 x+ p8 Z0 Z$ d- _% v/ U" W
1.3697965144
8 f4 r! [5 ]5 N7 n0 H8 O$ \ 1.56484954037 c0 Z! m. a7 b
1.7586206696
9 K! L, C; V* v1 q% K$ J0 @' _, [ 1.87342924459 S5 a, b. ~# Q5 v5 f
1.86467703346 Y) P3 _ f! d) R3 z
1.7399865423
: V/ Z, l. c+ U2 z 1.5677198524% J9 I! ~, Q/ x
1.4305114197" @9 y- m" ]6 }. |7 i" h c6 F- E
1.3652029140$ I4 u% w, u8 {4 k( R
1.3976630564( W( [6 ?6 ?4 e) I; N8 k. S
1.5222760992
6 ?7 H7 q+ x0 ^, Y3 q 1.7367039797
! g' j$ @# e4 P4 x; O 2.0081290038
0 { d* p5 x: Q 2.3009967779
1 I" E! i* a, H- q7 j 2.5703639512
3 w7 |- m* f* A4 \' f 2.7815010920
% {( X$ v4 P& R 2.9399229339
3 N: P W) ^( q9 V, h4 C 3.04928868532 S3 t% U: e) u
3.1620606594
$ I5 s+ e$ ~; K9 R 3.29260857211 p$ M8 J) c0 L
3.4617286107
4 o+ K# a' U7 r. X1 C4 j( D9 l 3.6524711404 H P2 |0 i6 l+ p% A" Z
3.8536056813
( Z5 q$ G5 \7 |5 H3 ~ 4.03766985067 Q0 T3 }. m, W9 _
4.1765864955
" M8 H: Q1 u8 h! g8 o. @ 4.2926543731" e7 p& S5 n$ O9 |9 K1 ~: e1 j
4.4016889998
; R3 }; j: b% |9 k3 A: ~& Q 4.5725416388! k) q2 g3 u3 M2 e
4.8372970822
+ Q4 j7 g/ h3 p$ Y- h 5.2551538512
8 s* J" C: h: V! x3 O7 ^& C9 i 5.8268851450
3 M0 n: p, o" g5 L- Z" Q6 j4 N5 h 6.5219105301
4 I2 J+ T5 M$ Z+ F" t" [ 7.22703132816 r2 L' s* @% C( t
7.7372484744& n# |' r) v2 @) y' m; {2 D k0 g
7.92208891156 F, s8 I! i C& j5 n
7.7275145396- S( p) F0 y$ w- w7 p. _7 N
7.32710486613 G" h+ I' M) H+ g
6.8822972565
- x7 n4 F2 s6 D: o) y x 6.5387086913: s& l: F x- ]1 s0 ~6 k( j
6.3180473346
& j2 x$ @7 F! u9 a& ~5 T* `9 w 6.1935381449- I1 A6 e# E/ z5 K( Y
6.11285062999 ]+ X0 R% R9 t8 J- c' D9 K" S1 L1 u
5.9904236799
7 S0 ^; U2 p; G4 U* S. L 5.8283263426
/ H, {" Z7 s6 N) \$ B$ M 5.64371001723 C0 b' \# R! o
5.5253572482
' U4 l( `8 t% o; n4 d4 i 5.5287797621
7 H/ b; G) x' A4 O9 S& V2 q 5.7275306761# f& Z* \* b% P
6 g& r$ }5 _7 T* `" e 4 n0 y c! N' U" A6 I) ^$ c/ Y
H! a1 Z5 h5 f7 V
% \' G/ J% V% z! j. S, b' s6 Z
要求:1。制作成3D图形(如下图)
% E. J6 Z% B/ B: d6 p. T" I, [4 [1 D# W( `+ q# T
2。我们提供任意一组上面的数据,或者几个特定距离的横截面积值,都能得到不同的3D图形。- M+ P: U6 A/ @. C
3.可以切开任意点的横截面,看到该横断面的情况。
7 b ~! f( g6 L9 y
) V0 t$ M- P* }' I% P2 `" W
7 \, O# C: |2 W+ r |
