查看: 1547|回复: 6
[求助] 电脑开机自检问题?
发表于 2007-7-24 16:10:22 | 显示全部楼层 |阅读模式 来自: 中国河北邯郸
电脑开检自检时出现  The volume  is dirty? * S( G4 `0 j" [% f
怎么解决???
发表于 2007-8-1 14:28:37 | 显示全部楼层 来自: 中国山东淄博
是不是该整理硬盘了,建议用系统自带的碎片整理程序试试。。。
发表于 2007-8-1 15:08:18 | 显示全部楼层 来自: 中国山西晋中
运行“chkdsk /F” 修复磁盘错误
发表于 2007-8-1 17:09:03 | 显示全部楼层 来自: 中国广东韶关
没见过此现象,不知道楼主出现此提示是在自检的什么时候显示。
发表于 2007-8-2 01:19:38 | 显示全部楼层 来自: 中国浙江杭州
系统原盘可以修复
4 q, z! o$ U6 ~1 Y在选修复(R键)可以修
发表于 2007-8-2 22:25:25 | 显示全部楼层 来自: 中国湖北宜昌
单击“开始→运行”,在“运行”对话框中输入“regedit”打开注册表编辑器,依次选择“hkey_local_machine\system\currentcontrolset\control\session manager”子键,然后在右侧窗口中找到“bootexecute”键值项并将其数值清空,最后按“f5”键刷新即可。
发表于 2007-8-2 22:41:01 | 显示全部楼层 来自: 中国湖北宜昌
有篇文章可以参考下:8 c/ i$ _; Y3 Y, V9 }3 w& ?& X& G1 R
what you're experiencing is what Windows refers to as "setting the dirty bit" and what you have to do is unset that bit. Every time Windows XP starts, autochk.exe is called by the kernel to scan all volumes to check if the volume dirty bit is set. If the dirty bit is set, autochk performs an immediate chkdsk /f on that volume. Chkdsk /f verifies file system integrity and attempts to fix any problems with the volume. It is usually caused by a hard shut down or a power loss during a read-right operation on that particular drive.+ D0 Z/ }  w% t' K* k. O
, q: W* |5 K% j& X' o. I  e
How do I fix it, you ask?/ ?" p/ P' E; T/ l$ m6 B& G, ~
& B8 @0 x9 U* x+ z0 Z
Well, that's easy. First click Start> Run> bring up a command prompt by typing in "CMD" and type " fsutil dirty query d: ". This queries the drive, and more than likely it will tell you that it is dirty. Next, type "CHKNTFS /X D:". The X tells Windows to NOT check that particular drive on the next reboot. At this time, manually reboot your computer, it should not do a Chkdsk and take you directly to Windows.2 ]* v2 S0 f" n' Z
  [8 m( {# d: P3 g  ~# JOnce Windows has fully loaded, bring up another CMD prompt and type and now you want to do a Chkdsk manually by typing "Chkdsk /f /r d:". This should take you through 5 stages of the scan and will unset that dirty bit. Finally, type "fsutil dirty query d:" and Windows will confirm that the dirty bit is not set on that drive.
+ [: b0 S+ T% L$ K1 e( v5 ?6 z3 K/ |& R( s: Z6 E( s
大意是每次WINXP启动都提示"setting the dirty bit" ,然后扫描所有驱动卷
: O  y8 Q1 z5 a6 o4 [9 M+ ^# S$ ~修复方法:1.开始-运行,输入CMD
, X: J3 k1 z$ P1 z2.输入"setting the dirty bit" 确定是否设置了卷的页面重写标志位  t5 l; k/ S- d. X
3接着输入 "CHKNTFS /X D:" X参数是告诉WINDOWS在此次重启后不进行卷检查5 q# N6 P- q/ p' x
4.进入WINXP后,输入CMD9 q4 f3 q9 u# a/ f6 R
5.输入"Chkdsk /f /r d:"' Y3 o) [- n& H  l7 ~
6.输入"fsutil dirty query d:" . ^) E" E. w1 L
:为出错的分区
