Win2000命令全集
7 z) v& e9 M* D, n0 C8 _) |accwiz.exe > Accessibility Wizard for walking you through setting up your machine for your mobility needs. 辅助工具向导 acsetups.exe > ACS setup DCOM server executable actmovie.exe > Direct Show setup tool 直接显示安装工具 append.exe > Allows programs to open data in specified directories as if they were in the current directory. 允许程序打开制定目录中的数据 arp.exe > NETWORK Display and modify IP - Hardware addresses 显示和更改计算机的IP与硬件物理地址的对应列表 at.exe > AT is a scheduling utility also included with UNIX 计划运行任务 atmadm.exe > Displays statistics for ATM call manager. ATM调用管理器统计 attrib.exe > Display and modify attributes for files and folders 显示和更改文件和文件夹属性 autochk.exe > Used to check and repair Windows File Systems 检测修复文件系统 autoconv.exe > Automates the file system conversion during reboots 在启动过程中自动转化系统 autofmt.exe > Automates the file format process during reboots 在启动过程中格式化进程 autolfn.exe > Used for formatting long file names 使用长文件名格式 bootok.exe > Boot acceptance application for registry bootvrfy.exe > Bootvrfy.exe, a program included in Windows 2000 that notifies the system that startup was successful. Bootvrfy.exe can be run on a local or remote computer. 通报启动成功 cacls.exe > Displays or modifies access control lists (ACLs) of files. 显示和编辑ACL calc.exe > Windows Calculators 计算器 cdplayer.exe > Windows CD Player CD播放器 change.exe > Change { User | Port | Logon } 与终端服务器相关的查询 charmap.exe > Character Map 字符映射表 chglogon.exe > Same as using "Change Logon" 启动或停用会话记录 chgport.exe > Same as using "Change Port" 改变端口(终端服务) chgusr.exe > Same as using "Change User" 改变用户(终端服务) chkdsk.exe > Check the hard disk for errors similar to Scandisk 3 Stages must specify a Drive Letter 磁盘检测程序 chkntfs.exe > Same as using chkdsk but for NTFS NTFS磁盘检测程序 cidaemon.exe > Component of Ci Filer Service 组成Ci文档服务 cipher.exe > Displays or alters the encryption of directories [files] on NTFS partitions. 在NTFS上显示或改变加密的文件或目录 cisvc.exe > Content Index -- It's the content indexing service for I 索引内容 ckcnv.exe > Cookie Convertor 变换Cookie cleanmgr.exe > Disk Cleanup, popular with Windows 98 磁盘清理 cliconfg.exe > SQL Server Client Network Utility SQL客户网络工具 clipbrd.exe > Clipboard viewer for Local will allow you to connect to other clipboards 剪贴簿查看器 clipsrv.exe > Start the clipboard Server 运行Clipboard服务 clspack.exe > CLSPACK used to create a file listing of system packages 建立系统文件列表清单 cluster.exe > Display a cluster in a domain 显示域的集群 _cmd_.exe > Famous command prompt 没什么好说的! cmdl32.exe > Connection Manager Auto-Download 自动下载连接管理 cmmgr32.exe > Connection Manager 连接管理器 cmmon32.exe > Connection Manager Monitor 连接管理器监视 cmstp.exe > Connection Manager Profile Manager 连接管理器配置文件安装程序 comclust.exe > about cluster server 集群 comp.exe > ComClust Add, Remove, or Join a cluster. 比较两个文件和文件集的内容* compact.exe > Displays or alters the compression of files on NTFS partitions. 显示或改变NTFS分区上文件的压缩状态 conime.exe > Console IME IME控制台 control.exe > Starts the control panel 控制面板 convert.exe > Convert File System to NTFS 转换文件系统到NTFS convlog.exe > Converts MS IIS log files 转换IIS日志文件格式到NCSA格式! X, W. ~1 ?! H0 q6 _
cprofile.exe > Copy profiles 转换显示模式 cscript.exe > MS Windows scripts Host Version 5.1 较本宿主版本 csrss.exe > Client Server Runtime Process 客户服务器Runtime进程 csvde.exe > Comma Separated variable Import/Export Utility 日至格式转换程序 dbgtrace.exe > 和Terminal Server相关 dcomcnfg.exe > Display the current DCOM configuration. DCOM配置属性 dcphelp.exe > ? dcpromo.exe > Promote a domain controller to ADSI AD安装向导 ddeshare.exe > Display DDE shares on local or remote computer DDE共享 ddmprxy.exe > debug.exe > Runs Debug, a program testing and editing tool. 就是DEBUG啦! dfrgfat.exe > Defrag FAT file system FAT分区磁盘碎片整理程序 dfrgntfs.exe > Defrag NTFS file system NTFS分区磁盘碎片整理程序 dfs_cmd_.exe > configures a Dfs tree 配置一个DFS树 dfsinit.exe > Distributed File System Initialization 分布式文件系统初始化 dfssvc.exe > Distributed File System Server 分布式文件系统服务器 diantz.exe > MS Cabinet Maker 制作CAB文件 diskperf.exe > Starts physical Disk Performance counters 磁盘性能计数器 dllhost.exe > dllhost is used on all versions of Windows 2000. dllhost is the hedost process for all COM+ applications. 所有COM+应用软件的主进程 dllhst3g.exe > dmadmin.exe > Disk Manager Service 磁盘管理服务 dmremote.exe > Part of disk management 磁盘管理服务的一部分 dns.exe > DNS Applications DNS doskey.exe > recalls Windows command lines and creates macros 命令行创建宏 dosx.exe > DOS Extender DOS扩展 dplaysvr.exe > Direct Play Helper 直接运行帮助 drwatson.exe > Dr Watson for 2000 Fault Detector 华生医生错误检测 drwtsn32.exe > Dr Watson for 2000 viewer and configuration manager 华生医生显示和配置管理 dtcsetup.exe > Installs MDTC dvdplay.exe > Windows 2000 DVD player DVD播放 dxdiag.exe > Direct-X Diagnostics Direct-X诊断工具 edlin.exe > line-oriented text editor. 命令行的文本编辑器(历史悠久啊!) edlin.exe > line-oriented text editor. 命令行的文本编辑器(历史悠久啊!) esentutl.exe > MS Database Utility MS数据库工具 eudcedit.exe > Private character editor Ture Type造字程序 eventvwr.exe > Windows 2000 Event Viewer 事件查看器 evnt_cmd_.exe > Event to trap translator; Configuration tool evntwin.exe > Event to trap translator setup exe2bin.exe > Converts EXE to binary format 转换EXE文件到二进制 expand.exe > Expand Files that have been compressed 解压缩 extrac32.exe > CAB File extraction utility 解CAB工具 fastopen.exe > Fastopen tracks the location of files on a hard disk and stores the information in memory for fast access. 快速访问在内存中的硬盘文件 faxcover.exe > Fax Cover page editor 传真封面编辑 faxqueue.exe > Display Fax Queue 显示传真队列 faxsend.exe > Fax Wizard for sending faxes 发送传真向导 faxsvc.exe > Starts fax server 启动传真服务 fc.exe > Compares two files or sets of files and their differences 比较两个文件的不同 find.exe > Searches for a text string in file or files 查找文件中的文本行 findstr.exe > Searches for strings in files 查找文件中的行 finger.exe > Fingers a user and displays statistics on that user Finger一个用户并显示出统计结果 |
