三维网:为中国机械制造行业提供全方位的信息资讯!
FTP搜索 | 下载论坛附件流量兑换 | 在线充值 | QQ客服1| QQ客服2 | 繁體中文
UG、Pro/E最新全套视频教程(34DVD)(推广)
返回列表 下一主题 ›› ‹‹ 上一主题 回复 发帖
[分享] CATIA P3 V5R19 SP0 Setup (Upgrade Setup P2 V5R19 to P3 V5R19)
CATIA P2 V5R19 SP0 Setup and  CATIA P3 V5R19 SP0 Setup differ by only several files, so it is possible to create CATIA P3 V5R19 SP0 Setup by adding into CATIA P2 V5R19 SP0 Setup necessary files from CATIA P3 V5R19 SP0 Setup三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa  ]# y/ u5 }( ^: q8 O; j
$ J2 H! k6 U3 r0 K三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江: H4 z  Z" c) T; S( Q
To do it you need (example for Win32 Setup)三维网技术论坛6 K# i6 y; ]) g6 r) ]9 v
) `2 z2 v7 o8 Kwww.3dportal.cn1) Download CATIA P2 V5R19 SP0 Setup ( DSS CATIA P2 V5R19 SP0 Win32.iso  from
http://www.3dportal.cn/discuz/viewthread.php?tid=606823 or anythere else)三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa7 l& `, Q, H5 }" K
  J8 o& ]7 c* p) l/ P  a" q三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa2) Download archive catia_V5R19_P2-P3_Win32.rar from this topic0 }" a: d4 x2 M1 P3 h! {0 a- r- T4 ]
三维网技术论坛& s. R  n9 B+ K8 o
三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa4 c( R4 n$ R* y$ E; s- i9 p% A
3) Using WinRAR extraxt files from DSS CATIA P2 V5R19 SP0 Win32.iso (
http://www.3dportal.cn/discuz/viewthread.php?tid=606823 ) to some folder on your hard disc' v# e& U' u) }% L0 E5 ?
# ^' V( z/ A) I三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa4) Extraxt to that folder all folders and files from archive catia_V5R19_P2-P3_Win32.rar (with overwriting files and folders with the same name)
7 ~* |, k4 U! K5 y/ Q三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa  P( T  l- m4 ]" o
So you will get CATIA P3 V5R19 SP0 Setup installation folder
( a. c: \# V4 F: q# mwww.3dportal.cn
  X( c* o, v7 ]# ?* X8 N  T三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxaAfter that you can:
2 \* i+ {' K3 S& M/ P5 Hwww.3dportal.cn三维网技术论坛/ j* N/ L2 [& l
1) Install  CATIA P3 V5R19 SP0 from that folder by running setup.exe
# M. }6 }! {0 F. T' a2 @ATTENTION! The name of this  Setup Folder abd path to it have to contain only ENGLISH letters!www.3dportal.cn) A% z9 W/ E7 b
5 Q- z! _1 U& e# x三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxaorwww.3dportal.cn+ S( t0 j9 N: ~; U0 A
www.3dportal.cn& r, T, `4 _: \+ L
2) Write that folder to DVD and install CATIA P3 V5R19 SP0 from that DVD by running setup.exe三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa) F6 i7 U) o! L* P3 C. n
* _( U6 Q& E; G1 m: m/ }三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江or三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江# n; q5 c$ s3 j! {8 K2 n
) `! q# a4 j  @/ S+ M三维网技术论坛3) Create an ISO from that folder (using any ISO Editor like UltraISO, PowerISO... ets) and Install  CATIA P3 V5R19 SP0 from that ISO
0 y6 b- _0 a5 S8 `( Uwww.3dportal.cnwww.3dportal.cn! m# i, i  q0 E; I+ d  E: p$ F
The action for creating of CATIA P3 V5R19 SP0 Setup for Win64 is the same, but you need to get  DSS CATIA P2 V5R19 SP0 Win64.iso and catia_V5R19_P2-P3_Win32.rar三维网技术论坛) F" B8 p/ d* C4 A4 \2 f! u
三维网技术论坛4 q, d* ~) D- m2 I% V7 @5 O- X. f
Cracks for P3 V5R19  installatins are the same I have posted for P2 V5R19
$ u* e+ }( P0 F# z/ n, G三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江( c2 a+ e( V6 j( }- W* v
I will be very grateful if someone will translate this instruction to the Chinese Language
1 ~2 m" m* M2 T7 x3 ]8 @  X6 k- E三维网技术论坛
/ g- T( y" I  X三维网技术论坛
5 i3 {3 p! ?% z* [, ]三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa[ 本帖最后由 solid_user 于 2008-12-9 16:27 编辑 ]
附件: 您所在的用户组无法下载或查看附件
1次
评分人:月光族 三维币 + 8 点 理由:好资料,感谢您对论坛的支持!
谢谢,我用的是64位,还是有老问题,选择相关产品模块后就打不开了?不知道是什么原因?
引用:
原帖由 WHZwhz 于 2008-12-9 11:10 发表 , o0 u# [/ Z' E( Z9 |  G% d
三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa( z! }% ^! O- t' A; u
Did you use a crack for JS0GROUP.dll and what crack did you use?
下来看看,谢谢!!!
64位的sp0 Crack以后没有问题。升级以后有2楼的问题。
引用:
原帖由 wwj402 于 2008-12-9 23:12 发表 三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江9 [# y' R% h9 q1 C( {3 @
1 j1 V  J3 Q& y  Twww.3dportal.cnexplain in greater detail what problems with crack do you mean?
) ]7 }: l/ m# N% H8 z4 G7 t三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江P3版本的三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江9 l, g, J2 b2 ?) @: T
是种子吗
是sp0下载时同时下载的Crack,sp0用Crack补丁后没问题;这个补丁不是覆盖JS0GROUP.dll ,是放在安装目录执行的。
( j; [3 b- ]$ g2 y# uwww.3dportal.cn升级sp2后,用sp2同时下载下来的Crack补丁,就是2楼的情况;可以删除用户下的setting,又可以启动,配置后再启动就不行了,不知道什么原因?
已经下载了
: w% j7 a# d; I. h3 C三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江原来是安装程序的升级补丁
引用:
原帖由 wwj402 于 2008-12-10 01:30 发表 三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa4 z0 E$ H/ m# ?8 x& l1 v. i
7 Z$ I- e7 L* t% `" w9 o三维网技术论坛升级sp2后,用sp2同时下载下来的Crack补丁,就是2楼的情况;可以删除用户下的setting,又可以启动, ...
三维网技术论坛+ U) |3 U' u6 H+ Q$ R
三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江- e6 f6 U1 ~1 ~7 {" w
There are two variants of crack for CATIA V5R19 SP2 Win64
4 c  g, f: J: F; }  [三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxahttp://www.3dportal.cn/discuz/viewthread.php?tid=607499
' o4 c9 _) G5 O$ F三维网技术论坛http://www.3dportal.cn/discuz/viewthread.php?tid=609780
, Z. s; l6 `0 ~- Q& p' A: YWhat crack did you use?
P3哪里有下载?
谢谢楼主了
谢谢LZ的详细指导及分享!
The crack  for P2 V5R19 is used in a P3 V5R19, the message is shown. Please LZ check it. Thanks!
R19与R17有区别马?
非常感谢楼主的耐心回答。这个修复版http://www.3dportal.cn/discuz/viewthread.php?tid=609780,没问题了,一切正常。再次衷心感谢。
用google翻译的,略加修改。
4 A, h0 Q: ?$ ]& C! W- p三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江
1 Q+ t2 g) t2 t8 M1 S& Z3 N# Y1 Swww.3dportal.cnCATIA的P2 V5R19 SP0的安装文件和CATIA P3 V5R19 SP0的安装文件只是几个文件不同,因此有可能通过添加覆盖这些不同的文件到CATIA的的P2 V5R19 SP0安装文件中得到CATIA的P3 V5R19 SP0安装文件。三维网技术论坛# C  V( C$ z/ x4 o" ^
: ?3 {' D, O! c# O三维网技术论坛要做到这一点你需要(例如Win32版的安装)www.3dportal.cn1 e& N8 I: k# `
) L9 O* D  M: B( I. Q7 Z$ c& t- F三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江1 )下载CATIA的的P2 V5R19 SP0安装程序( CATIA的P2 V5R19 SP0 Win32.iso从http://www.3dportal.cn/discuz/viewthread.php?tid=606823或其他地方获得 ) ;三维网技术论坛7 H, K! L; ]% N; l
( F7 e0 R+ n( \
2 )从这个主题下面的附件中,下载档案catia_V5R19_P2 - P3_Win32.rar;
4 r3 p# H7 Q7 E. W8 g& w' ^- n: x三维网技术论坛
/ _. g, J+ z& O三维网技术论坛
% ~8 H' _% }& Z1 O: B三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa3 )使用工具从CATIA的P2 V5R19 SP0 Win32.iso ( http://www.3dportal.cn/discuz/viewthread.php?tid=606823 )镜像中提取所有文件到您的硬盘文件夹中(最好不要使用中文名的文件夹,直接从这个文件夹安装可能会有问题); - W  Q" x# n1 N" M7 Z
三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江! o: ^! g1 a/ c0 |6 ^3 |: W
4 )解压catia_V5R19_P2 - P3_Win32.rar 中的文件到硬盘上CATIA的P2 V5R19 SP0 Win32.iso提取的文件夹(覆盖相同的文件和文件夹) ;2 j2 L: w) M& d  f9 ~1 \# h$ T
) ~3 S; N* i8 J' `8 d  c三维网技术论坛所以,您将获得CATIA的P3 V5R19 SP0安装程序的安装文件夹三维网技术论坛+ t: X; D4 A* \& h
三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa1 _% M* l; c2 D
在此之后,您可以:
& H+ I0 V, q& b; b. [" E' b三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江8 R) F6 A9 x2 B1 W
1 )安装CATIA的P3 V5R19 SP0从该文件夹中运行的Setup.exe
: T" G- h# ^$ W$ t) Bwww.3dportal.cn注意:setup的所有路径,必须只包含英文字母! 三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江  ^) Y; \. ^# k
" r$ X- C" Q" c# }* W三维网技术论坛
" c8 N0 Y  B$ u三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江
& e" Q9 [( d; g* e  i; V7 Xwww.3dportal.cn2 )把该文件夹下的文件和文件夹刻录到DVD中;安装CATIA的P3 V5R19 SP0从DVD的运行的Setup.exe
2 g, @3 k' _& S6 R( L6 }三维网技术论坛三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江+ u; r' \" `. o  u* K, a
8 ~+ R, x: V/ `8 j& Q0 m$ i! J! |www.3dportal.cn三维网技术论坛( r0 y$ C% A/ P9 E
3 )从该文件夹创建一个ISO(使用任镜像编辑工具如UltraISO, PowerISO ... ETS );加载这个ISO安装CATIA的P3 V5R19 SP0。 www.3dportal.cn9 I/ ~# Q5 i2 O% c0 s/ [8 V
三维网技术论坛) Q, Z% L/ H( r- T
CATIA的P3 V5R19 SP0 Win64版是相同的,但是您需要获得CATIA的P2 V5R19 SP0 Win64.iso和catia_V5R19_P2 - P3_Win32.rar
7 H, B. F* h" R三维网技术论坛三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江+ [1 J7 t/ U+ Y& a# ^. v" D
P3 V5R19 的Crack和P2 V5R19Crack相同。
引用:
原帖由 winster 于 2008-12-10 13:28 发表
+ A( ?  ]! e  t, q3 R三维网技术论坛The crack  for P2 V5R19 is used in a P3 V5R19, the message is shown. Please LZ check it. Thanks!
www.3dportal.cn& X  Y- T8 ?" R* x$ J5 _
Any patch mast be apllyed to origial (not already cracked by another patch!) JS0GROUP.DLL3 m5 b( k: q, w* I
www.3dportal.cn& k2 T; G6 F: `+ ~* H  ?
Did you install P3 above already installed and cracked P2?
1 {/ r) y& P! v4 B  H
9 I2 ]; \0 f7 C2 s3 @三维网技术论坛[ 本帖最后由 solid_user 于 2008-12-10 23:03 编辑 ]
very good!thank you
谢谢。 很有帮助
谢谢楼主,我是新手,CATIA P2 V5R19 SP0 Setup 无法显示,如何解决?
引用:
原帖由 solid_user 于 2008-12-10 18:16 发表 三维网技术论坛: t( b: R8 o' A. \* [. Z
' {0 z9 S1 I! t; [三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxaAny patch mast be apllyed to origial (not already cracked by another patch!) JS0GROUP.DLL
6 V. I4 B0 X4 b: ]& `三维网技术论坛三维网技术论坛6 @8 R' q/ [' K, W
; H$ h6 h5 J8 P( K三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江( P# |/ n( U; ]9 i3 [3 k
Thank you for your feedback. The following is my  "JSOGROUP.DLL".
引用:
原帖由 winster 于 2008-12-11 06:50 发表
6 q9 }  [" c( q  ^. B3 N5 y* \0 a
, u0 Z" B( l$ i+ v! Q
  Q6 V; y* E" y& F0 y! f8 d+ V三维网技术论坛Thank you for your feedback. The following is my  "JSOGROUP.DLL".
# L5 H0 I% P! S& s三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxaIt is JS0GROUP.DLL from V5R19 SP0 Win32 !!! I三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa- i% x9 h- _" D3 l
三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxa$ A% Q" ^  b* u3 l
What the hell you a trying to patch it with crack for V5R19 SP2 Win64 ??????
引用:
原帖由 solid_user 于 2008-12-11 15:59 发表
2 V$ Y, k/ b/ x三维,cad,机械,技术,汽车,catia,pro/e,ug,inventor,solidedge,solidworks,caxa,时空,镇江: J' D1 H8 w! P. [) ?, Y" c' \
: [0 p6 |# ^0 m5 M% L, K  N三维网技术论坛
3 ^/ i# l# V; T2 Y" @4 S- r三维|cad|机械|汽车|技术|catia|pro/e|ug|inventor|solidedge|solidworks|caxaWhat the hell you a trying to patch it with crack for V5R19 SP2 Win64 ??????
6 h& L, \7 m* {; m3 l) \三维网技术论坛www.3dportal.cn1 c( o& h  @  V
I patched it with the crack for V5r19sp2 with Win32 instead of V5r19sp0. Now it's ok. Thanks for your answer.
thanks for this. i installed catia p3 with this, applied the sp2. i use the fixed 64bit crack mentioned here, but everytime i select a licence and restart, the program won't start. when i remove the licence, the program starts, but asks me to select a licence again. does anybody have a suggestion?
0 y! v0 U8 F- p; y' l5 e+ x6 ?
7 _; u3 M' a* Zthanks.
