- 帖子
- 10
- 积分
- 126
- 流量
- 219684 K
- 注册时间
- 2006-10-25
weldable adj. 可焊的
weldless adj. 无焊缝的
weldment n. 焊(接)件
double-bevel groove weld 双斜边坡口焊缝, K形坡口焊缝
butt weld 对接焊缝
groove weld 坡口焊
contour weld 特形焊接
automatic spot weld 自动点焊法
explosive weld 爆炸焊接
gas-pressure weld 气压焊
concave fillet weld 凹角焊
downhand weld 平焊缝
carbon arc weld 碳极弧焊
braze welding 硬焊, 铜焊, 钎焊
air-acetylene welding空气-乙炔焊接
argon arc welding 氩弧焊
automatic slag-pool welding 自动电渣焊
aircomatic welding 自动调弧氩弧焊, 惰性气体保护金属极弧焊
aluminothermic welding 铸焊, 铝热剂焊接
butt welding 对接焊, 对焊
austenite welding 不锈钢(焊条)焊接
automatic submerged arc welding 自动埋弧焊
argon shielded arc welding 氩护电弧焊
weld all around围焊
weld appearance驾吨焊缝外观
welding powder 焊粉
weldable steel可焊钢;焊接钢
weldable copper可焊复合铜板
non-weldable steel不可焊接的钢
high strength weldable aluminium alloy高强度可焊铝合金
weldable可焊的
non-weldable不可焊接的
weldable strain gauge悦焊接式应变计
weldbonding粘焊(指电阻点焊与用粘胶粘接相结合的焊接)
welddecay[冶]焊接区晶间腐蚀
welded all around(round)沿周边焊接的
lap welded casing搭焊套管
welded aluminum alloy(WAA)焊制铝合金
welded and expansion joint焊接加胀接法
welded and rolled tube joint焊胀
welded armor焊接甲板
welded attachment焊接附件
welded austenitic stainless steel pipe焊接奥氏体不锈钢钢管
welded bellows焊接波纹管
welded body焊接车身;焊体
welded bond焊接轨隙连接器
welded cap焊接管封头
projection welded cap凸焊帽;有凹凸的焊帽
welded bridge焊接桥, 焊接桥梁
welded casing焊接套管
welded case焊接机匣
helically-welded case螺旋焊接壳体
welded chain焊接链
welded cathode焊接阴极
welded connection焊接合,焊接头,焊接联结
shop-welded connection厂焊接头
welded construction 焊接结构
all-welded construction全焊结构
welded contact rectifier熔接整流器
welded corner joint角焊接
welded crossing焊接断面
welded digester焊接蒸煮锅
welded elbow焊接机械肘, 焊接弯头
welded encapsulation焊接封装
welded ends焊接连接端
welded fin tube焊片式翅片管
welded fissure焊接裂缝,焊合的裂缝, 焊接裂纹
welded fitting焊接式管接头
welded flange焊接法兰;焊接翼缘
manhole with common welded flange平焊法兰人孔
manhole with butt welded flange对焊法兰人孔
handhole with butt welded flange对焊法兰手孔
welded flat head焊接式平盖
welded frame焊接骨架, 焊接车架, 焊接隔框
tubular welded frame scaffold管状焊接框架式脚手架
welded frog焊接辙叉
welded gasket焊接垫
tie-in weld管段间焊接
powder weld process粉末焊接法
intermittent fillet weld断续角焊缝
edge weld端接焊缝
tack weld定位焊
backing run; backing weld打底焊道
strapped weld; strapped joint搭板对接焊缝
strength weld承载焊缝
lap fillet welding搭接角焊
overlap welding; lap welding搭接焊
magneticetic pulse welding磁力脉冲焊
flywheel type friction welding; inertia welding储能摩擦焊
stored energy welding储能焊
percussion welding冲击焊
workshop welding车间焊接
explosive welding爆炸焊接
blasting welding factory爆破焊接厂
welded eye焊眼
welded elbow; welded ell焊接直角弯头
welded nut焊接螺母
welded tank焊接罐
welded pipe焊接管
ratio-frequency welded tube高频焊管
furnace butt-welded pipe对接炉焊管
hammer welded pipe锻焊管
concave fillet weld凹形角焊缝
automatic spot weld自动点焊法
butt weld对接焊缝
carbon arc weld碳极弧焊
concave fillet weld凹角焊
contour weld特形焊接
double-bevel groove weld双斜边坡口焊缝, K形坡口焊缝
downhand weld平焊缝
explosive weld爆炸焊接
gas-pressure weld气压焊
groove weld坡口焊
heliarc weld氦弧焊
inert gas carbon-arc weld惰性气体保护碳弧焊接
inert gas metal-arc weld惰性气体保护金属极弧焊
intermittent weld间断焊缝
lap(seam) weld搭接焊缝; 搭接焊
laser weld激光焊
multiple-electrode submerged arc weld多电极埋弧焊
multiple-pass weld多道焊缝
non-pressure weld熔焊, 不加压焊接
overhead fillet weld仰焊角焊缝
oxyacetylene weld氧[乙]炔焊, 气焊
oxygen weld氧气焊接, 气焊
projection weld凸焊
resonance butt weld谐振式对接焊
scarf weld斜面焊接, 两端搭接焊, 嵌接焊
semi-automatic arc weld半自动电弧焊
shot weld点焊
fusion pressure welding熔化压接
fusion thermit welding熔化铅热焊
gas-electric welding气电联合焊接
gas metal arc welding气体保护金属极电弧焊, 熔化极气体保护焊
gas shielded arc welding气体保护焊, 气体保护弧焊
gas shielded magnetic flux arc welding磁性焊剂气体保护焊
gas torch welding炬焊
gas tungsten arc welding钨电极惰性气体保护焊
girth welding环缝焊接
gravity welding重力焊, 重力式电弧焊
hammer welding锻接
hard facing arc welding表面加硬电弧焊
heated-tool welding热烙铁焊接
helium shielded welding氦气保护焊接
hidden arc welding潜弧焊, 埋弧焊
high-frequency induction welding高频感应焊接
horizontal fillet welding水平角焊接
horizontal-rolled-position welding滚动水平焊, 水平转动焊接
hydrogen atomic welding原子氢焊接
induction resistance welding感应电阻焊接
indirect spot welding间接点焊
inert gas shielded-arc welding惰性气体保护焊
inert gas tungsten arc welding钨板惰性气体保护焊
inertial welding惯性焊接
jump welding丁字形焊
[ 本帖最后由 wwqq 于 2006-11-3 22:22 编辑 ] |
