起因:组装台式机从客厅搬到房间# O2 O9 L% m! `! X+ q
$ s a- C; i$ F/ z2 f- n0 U
出现问题:启动时进入windows xp滚动画面而且滚动条滚玩出现欢迎使用后又从头开始启动! ?" s' a& c* N& @. p. @/ z
9 I# c& [( N% o 而且可以顺利启动!这种情况大概10次开机有6-7次会出此情况而且都是插上电源
. S3 u. f% W3 ] + w: [4 _% v! f" h9 Q. @
第一次开机时,之后重启什么的都很顺利!
/ K# J4 z& o' V9 d3 a9 H% I( Y
2 n# \( W- W- X" m* B# d6 s3 Z 由于总这样有点不爽于是显卡、内存、硬盘我都有拔下来擦过再插上!但没有效果涛声依旧!4 a6 r( S' \+ j
7 x! L4 v, `% D; I/ d: T
逼不得已重装系统(ghost版本xp)上述问题不会发生了但又出新问题---启动时蓝屏!2 w0 {5 N U1 U- P$ r, u
# ^/ _$ y7 N. x" c6 d
而且同上面情况一样进入windows xp滚动画面而且滚动条滚玩后就出现蓝屏--重启还是可以顺利启动0 P( w0 A" j$ y k2 W
" Y/ q6 K- A. ]% m7 R
现在每天回去第一次开机就如上所述蓝屏,但后面重启什么的也都还ok!0 S! A2 G' J# N% g
, v/ t4 U6 ^; j1 Q* X下面是有一天的蓝屏信息(昨天代码是0x00000050)5 T4 Z+ G, M: M% p7 U& f) I
a problem has been detected and widows has been shut down to prevent damage to
0 C& j3 q: W5 n( u7 ]5 y5 m6 y- @( v+ m7 pyou computer.) X! X7 F# o9 `2 F1 }2 F5 p" N
irql_not_less_or_equal
& @% q' r" a/ L2 s0 G4 Oif this is the first time you've seen this stop error screen,restart your computer.8 l0 s5 S' X' A1 Z, g8 _
if this screen appears again,follow these steps:0 y. {: A4 j: f! |& R0 z& E0 I4 C
check to make sure any new hardware or software is properly installed.
6 f% C* h" L! C. yif this is a new installation,ask your hardware or software manufacturer* G k2 U3 i. Y3 u# b9 H# A
for any windows updates you might need,9 r& x! ~) S' ?
if problems continue,disable or remove any newly installed harddware or software.
* F. e2 U6 Y5 a, w* Jdisable bios memory options such as caching or shadowing.
0 i6 S9 s; P; W" Z% \8 zif you need to use safe mode to remove or disable components,restart your
2 w5 `9 g4 h* v, }, Qcomputer,press f8 to select advanced startup options,and then select safe mode.5 j: i4 i4 |; C+ n# l7 [
technical information:: W' T) _6 t( {2 L! y8 h! f
***stop:0x0000000A(0X0007B000,0X00000002,0X00000001,0X80520649)0 B- a( q. E: i7 \0 |% W0 e
/ r, d( ~. _( h0 i' I
# i* o0 @& x& V* G
请各位兄弟姐妹仁者见、仁智者见、智集思广益给出点主意0 K( G$ p- n7 k4 P, z n$ a5 T
/ b" W: n% i7 L$ A; M0 o
我天天看着那个蓝屏心里堵得慌!拜托大伙儿了!先谢了! |
