- 积分
- 100454
UID3
主题
在线时间 小时
注册时间2006-1-1
Winamp v5.57版本正式发布!% X: I. T7 b& L) `+ u4 `, [1 O/ f2 n
http://download.gdownload.nullsoft.com/winamp/client/winamp557_full_emusic-7plus_en-us.exe: g h% w& v. _, j
- D2 C9 q( o/ q5 M, Hhttp://download.gdownload.nullsoft.com/winamp/client/winamp557_pro_all.exe w: ?& ^1 m0 E0 s6 y4 a3 M
; N3 \' i0 `7 o2 J9 O# M( H" O
8 o; Y; b4 M/ L5 N9 p& s. i
8 I0 m1 n9 `4 u$ d: ]
Winamp 5.576 e7 X; W) {' j& L1 }
* New: MPEG-4 video support for in_mp4 & in_flv (Winamp Pro only)
4 L, g' \7 y" x4 L9 t4 }* New: [in_avi] Native AVI video support (MPEG-4 = Winamp Pro only)
+ ]( @, y$ d3 A; v, e/ D, K2 {! l% y( F* New: [in_mkv] Matroska MKV video support (MPEG-4 = Winamp Pro only)
. M4 R0 C- f+ F4 ]* New: [ml_addons] Browser for discovering new skins & plugins" I& s, A. B6 B3 g5 z- T) n
* New: Winamp detection browser plugins for IE & Firefox" w0 j. l6 G* p, _& ]7 C
* Improved: Direct3D video rendering
5 j, U$ G8 r7 O* Improved: Filetype association handling on Vista & Windows 7
% x( Z( g y, x6 O' y! I1 w `* Improved: New fullscreen video OSD
4 f" r# o7 w2 J0 N0 @4 }* Improved: Added ReplayGain Preamp control to Prefs (previously .ini only)6 }( ?( d; F8 s7 a
* Improved: VU meter (beat vis) optimizations* `& r; q: Z* Z6 Q& X, L& `% f
* Improved: [gen_ff] Multithreaded <AlbumArt/> object7 ?( k' U1 u6 |
* Improved: [in_flac/in_vorbis] Tag support for Organization field as Publisher4 t1 s% ]2 j6 l+ c
* Improved: [in_flv] AAC, aacPlus & ADPCM audio support in FLV files" z r4 z/ x8 I
* Improved: [in_mp4] Support for aacPlus parametric stereo in mp4 container
) W$ h" P2 F9 [. E* Improved: [in_nsv] Native h.264 decoding (Winamp Pro only)
% i2 y; k H. i4 V/ z1 _ J* Improved: [in_wave] Unicode filename handling5 j( W m% V) p( m# j% [3 w2 Y$ _
* Improved: [ml_history] Play Offset feature for resuming playback of podcasts9 a* L, i. R3 m' Q- ]
* Improved: [ml_local] Director & Producer fields & columns for videos$ _3 {+ Q4 c( y0 q9 \6 i& a
* Improved: [ml_local] Row cache for NDE to vastly speed up queries
s! m4 p2 Z" G* J; u% }$ i* Improved: [ml_online] Right-click option to open service in new window
( M- g+ s% R7 q/ {6 {$ p0 F: G* Improved: [ml_wire] feed:// pcast:// and winamp:// protocol support
+ [' ~( U! }, N; f! n$ A* Improved: [ml_wire] Option to automatically download 'x' most recent episodes
" H2 U" a% v/ B0 N K8 O* t$ |* Improved: [ml_wire] Redesigned Podcast Directory view: b) P7 ]2 a% K& a3 `
* Improved: [pmp_usb] Option to set paths in saved playlists0 S2 }8 G u/ c0 c! P8 p4 J9 r
* Improved: [vis_milk2] Milkdrop2 updated to use ns-eel2 (thanks Justin)
/ _ U& N; g1 X1 c9 v* Fixed: Custom mldb info reverts to filename on Alt+3 for in_dshow, flv & swf5 y( p( p( V _' ?1 ^0 j5 N
* Fixed: HeapSetInformation not located in kernel32 error under Win2k8 }) R4 n. A* Q) H
* Fixed: Shuffle feature broken under limited user profiles
8 T) q3 H# L$ f' U! I* Fixed: [gen_ml] Bold text in Local Media views on some systems
3 G1 ^5 E9 m1 d- k+ @. A9 P; N* Fixed: [gen_tray] Compact mode not working on 64-bit OS
2 m9 ]8 J; E( K6 [1 d* Fixed: [in_flac] Playback freezing before end of some corrupted files
/ f% Q; m/ Y% M7 r- W- _* Fixed: [in_flv] Sync issue where video lags behind audio on some flv files
" h& }3 W' P B6 x* Fixed: [in_flv] Various h.263-related crash issues
6 e. m$ C) y! n. A: J2 b ?* Fixed: [in_mod] Heap overflow security vulnerability (thanks Dyon Balding, Secunia)! Y* P8 ~3 l/ d, b5 V8 |; a2 U
* Fixed: [in_mod] Some s3m files crashing on load9 P) X+ a( o6 b; q3 b9 f- m
* Fixed: [in_mp4] Various transcoding issues& m' j8 b* J4 F; Z6 m! T; |3 y
* Fixed: [in_wm] Main window & taskbar menu blocked after closing DRM browser
) _4 ?5 H) e* R B4 n( F' c* Fixed: [jpeg.w5s/png.w5s] Security vulnerability fixes (thanks Nicolas Joly, VUPEN)
7 ~" B: f9 w) F% h5 W8 y- _5 Q* Fixed: [ml_local] Remove missing files broken in full rescan {' D7 L: ^3 k5 }, t
* Fixed: [ml_wire] feeds.xml sometimes being destroyed. q& j5 ~8 e h
* Fixed: [pmp_p4s] Crashing with certain devices+ }9 O& h6 k& J" r% |; f
* Fixed: [vis_avs] Compile issues causing some presets to not load properly or crash
/ Z0 Y6 d! e& e4 M( r, N `* Misc: Improved Windows 7 compatibility, incl. aero thumbnail & taskbar integration
% ~3 m/ Y& K8 e* Misc: More general tweaks, improvements, fixes and optimizations0 F7 U" ~. h8 b) \5 q- x9 N- E
* Misc: New info page for lang pack developers in About Winamp dialog
: ~* }% d8 H$ x2 j/ k* Misc: New MPEG-4 video support adds h264.w5s & mp4v.w5s9 }+ z! e7 I0 A
* Misc: Renamed nsvdec_vp6.dll to vp6.w5s6 H3 j* y4 Y( X8 \% ^, F: j1 ]
* Misc: Removed gen_dropbox from the installer, for now...
$ }* |: ]# O- ^) Z% e' P. R* Misc: Right-click to close Notifier in Bento skin* e' `1 c' r( R
* Misc: Some keyboard accelerator fixes (new Ctrl+Alt+B for Add current to bookmarks)
) c* O9 ~8 h" Z/ m+ H* Misc: Various installer improvements (including new DirectX version checker)
/ E, u2 T/ z$ t' p. V* Updated: aacPlus decoder 8.2.2, encoder 8.2.02 s- k' B @9 q6 D* M) I
* Updated: Gracenote CDDB/MusicID v2.6.101* @* I& _! u1 t Y' C
* Updated: libpng 1.2.40. y9 s& i% h( F
* Updated: [gen_jumpex] JTFE v1.0.72 R3 z2 n# p3 P' f, F ~
* Updated: [in_vorbis] libvorbis 1.2.3 & libogg 1.1.4 |
