11天前
查看: 2321|回复: 13
[求助] 人世间最痛苦的事莫过于蓝屏!help me!
发表于 2009-11-10 10:41:11 | 显示全部楼层 |阅读模式 来自: 中国福建厦门
       起因:组装台式机从客厅搬到房间8 @/ i. e" F8 L. l
# [6 D+ n' ~2 m/ E6 c8 n7 C
出现问题:启动时进入windows xp滚动画面而且滚动条滚玩出现欢迎使用后又从头开始启动
! t4 o. X7 [, ?( v' |
% J/ S: e1 m3 H- |# U, e% x- {                 而且可以顺利启动!这种情况大概10次开机有6-7次会出此情况而且都是插上电源2 g' X# p. d1 V* `1 M* M2 [2 Z
  5 _$ B/ }4 p# u! L0 z
                 第一次开机时,之后重启什么的都很顺利!
+ w  Y  P( b" e0 y7 R& e; Y! W
: V2 `" {4 h6 g0 R/ h- R                 由于总这样有点不爽于是显卡、内存、硬盘我都有拔下来擦过再插上!但没有效果涛声依旧!
) u* S) Z1 G/ C, O1 n8 q! n
* A, D5 d7 k( y8 Q- Z& F2 Q                 逼不得已重装系统(ghost版本xp)上述问题不会发生了但又出新问题---启动时蓝屏!
/ M1 X9 {0 b( W0 H6 ]
( S, L; \' k4 H* x# p9 _                 而且同上面情况一样进入windows xp滚动画面而且滚动条滚玩后就出现蓝屏--重启还是可以顺利启动$ `( _/ _8 B# e; q" z( P, t( d- y
9 ]: t% Y; {6 Q8 H3 V7 Y                 现在每天回去第一次开机就如上所述蓝屏,但后面重启什么的也都还ok!. q/ e& [5 h) _$ C# ^: {
8 W; y0 z9 o  w- B5 L下面是有一天的蓝屏信息(昨天代码是0x00000050)
5 L% k( i' B: J4 Ca problem has been detected and widows has been shut down to prevent damage to 5 D* D- j; f* O7 R
you computer.
& ^/ t* x1 k  k' e% ]irql_not_less_or_equal$ M: @& Y8 L& ~( T
if this is the first time you've seen this stop error screen,restart your computer.3 \+ p1 w8 Z$ m2 H4 t& r; u
if this screen appears again,follow these steps:
, G+ o1 Q: D; M8 @$ Fcheck to make sure any new hardware or software is properly installed.
& s: T# J7 K$ l+ K: Iif this is a new installation,ask your hardware or software manufacturer) u" R+ x+ h0 m3 l
for any windows updates you might need,
! w* R2 f0 C( `! c& j1 y% w# eif problems continue,disable or remove any newly installed harddware or software.2 O9 K, |2 K) K6 X4 _0 n2 J
disable bios memory options such as caching or shadowing.- C% ]+ M8 @0 t( \
if you need to use safe mode to remove or disable components,restart your
% k* Q& n' `: o: u& H( `6 @computer,press f8 to select advanced startup options,and then select safe mode.
$ d+ x0 |0 ?. z0 K9 H5 ]( B5 S6 L7 `technical information:
7 T4 I8 V" m" ?* e' A# F$ u1 ~  Q1 d***stop:0x0000000A(0X0007B000,0X00000002,0X00000001,0X80520649)
, z. ^9 W) n: `3 b. G! m 3 c% x  X0 `7 w0 @% P! h0 ]$ {) t
( k6 l0 j7 n) J! _( g3 x
请各位兄弟姐妹仁者见、仁智者见、智集思广益给出点主意
( w  p) L0 M  @. i9 P$ X
" n+ o, N- K7 q+ `我天天看着那个蓝屏心里堵得慌!拜托大伙儿了!先谢了!
发表于 2009-11-10 11:24:31 | 显示全部楼层 来自: 中国北京
1、换个不是ghost的系统0 J4 t' G* G5 f; q0 b. N% |
2、如果是两条内存,每次只插一条,每个插槽轮流试一下,分别启动,目的是排除是不是内存问题或某条插槽有问题。  m  o6 `( R* t8 w0 C$ ]
; f( L# N7 x4 F( ~这两个可能最大一些
发表于 2009-11-10 11:26:31 | 显示全部楼层 来自: 中国山东烟台
换个版本的系统重新装一下试试吧:time:
发表于 2009-11-10 11:43:36 | 显示全部楼层 来自: 中国广东广州
重装系统,以前也有过
1 {' C4 Q& V( z" o一位是内存坏了* C/ |$ N! u7 A/ f( U+ J* @
结果DELL 工程师帮我把电脑的主板,内存全换了还是没有: ~) T% y" F1 T/ |* v! E0 @# B
重装就好了
发表于 2009-11-10 12:37:07 | 显示全部楼层 来自: 中国江苏苏州
 楼主| 发表于 2009-11-10 14:18:52 | 显示全部楼层 来自: 中国福建厦门
回复 2# h56kps 的帖子
我还真是两条内存!原来配的时候只有一条512今年上半年从一个同事那里搞了一个512, d3 \+ k2 D6 d# V" Z; `1 u
& g4 u0 l  ^+ S: M/ S' d5 X变成两条内存都是ddr2的但牌子不一样还是有点小区别不过已运行半年没出过什么事!
 楼主| 发表于 2009-11-10 14:20:12 | 显示全部楼层 来自: 中国福建厦门
原帖由 angelrain_gu 于 2009-11-10 11:43 发表 http://www.3dportal.cn/discuz/images/common/back.gif
8 |4 U  x6 u: M2 u* `重装系统,以前也有过
7 B# r- R4 w  j3 J6 z4 K一位是内存坏了
/ A3 y) l9 V: F* P3 \- T1 C' b, P4 }结果DELL 工程师帮我把电脑的主板,内存全换了还是没有
. C5 S2 H. s" H) x8 r重装就好了
+ X1 G, F1 B: g' q" e" }
0 S, o# j3 }% R+ Z% s--------------------------------------------------------------------------------: J8 G. u5 y3 ~+ M
我装了三次了!不过都是ghost版本的!
发表于 2009-11-10 14:54:11 | 显示全部楼层 来自: 中国浙江台州
是硬件问题 驱动不正常 那种ghost版本的很容易出现这种现象
发表于 2009-11-10 15:59:57 | 显示全部楼层 来自: 中国安徽芜湖
肯定是设备的问题,最好把机箱打开,把所有的硬件拔插一次。
5 v1 P7 z5 g  K$ m( U0 f. l根据你说的情况,可能是搬动电脑时,灰尘掉入什么地方所至。
发表于 2009-11-10 18:34:53 | 显示全部楼层 来自: 中国安徽合肥
建议重装系统,最好使用原版的主板驱动和显卡驱动
发表于 2009-11-10 19:17:47 | 显示全部楼层 来自: 中国台湾
應該是ram的問題 附上籃屏解讀器
) S7 I5 A# @* D2 y( \2 C+ X
: j$ c( c+ \0 x[ 本帖最后由 nba222 于 2009-11-10 19:20 编辑 ]
WINDOWS藍色當機畫面解讀.rar
76.65 KB, 下载次数: 15
发表于 2009-11-12 14:52:29 | 显示全部楼层 来自: 中国北京
发表于 2009-11-12 16:30:46 | 显示全部楼层 来自: 中国云南红河哈尼族彝族自治州
我觉得问题还是在内存上面,尽可能用同一品牌的内存条。
 楼主| 发表于 2009-11-21 10:33:21 | 显示全部楼层 来自: 中国福建厦门
感谢各位兄弟出谋划策!问题已经解决! - b- K) p- o' P, J, E
) ]3 H; q. j3 l, I
后来弄了一正版xp装了----蓝屏是不会了但第一次开机老是重复启动!
) _1 O* m; U, S" D- ~" ~2 K" a  E& P0 a
后来最终解决之道是-----拔掉一根内存(我两内存厂家不一样一条是捡别人的但都是ddr2 533), Q8 W6 R& }" d+ X* n. _+ F
/ U, p- f; N. C3 x. U/ y; z
有点郁闷的是用了半年没问题怎么这会儿就出毛病了?
! y8 I' O/ g( V/ Z3 Y' F  X. k
8 e! O8 y1 I4 H4 N' K1 r0 N问题总算解决了----再次甘感谢大伙儿!
