Delphi Multec® Diesel Common Rail
4 H, C" l' Q% D! x6 n% X' SA Value and - Performance Optimized Fuel Injection System
. p, H; y3 R6 O, |. M5 X, {• Functionality. u- }- N4 \% E8 Q& f# E% v9 v( z
– Fast acting solenoid based common rail system providing concise( s, B' z/ _) W0 E+ t) c0 C/ u# q
and accurate fuel management9 S5 L% O# q" ^) o J+ ~
– Flexible, application targeted injector range* t" G" n0 i/ s. ?( ]$ s
– Modular pump design
' B. Y: r( b# P; q– Advanced system strategies for engine management system (EMS)8 o3 t# R+ s, d$ d
control with accelerometer pilot injection (APC) and individual
2 `1 d; K' L* M- o9 jinjector characterisation (I3C)
3 Q$ ^8 T9 H0 ~ _4 D* Y4 n– Low voltage activation" c7 J0 d: _) l* o
• Delphi Advantage
) R! X6 z7 L% ?/ l– Extremely fast, equivalent to competitors servo-piezo injectors
% l$ v* V4 K' `" e. h s) V }performance+ n, M9 J/ F' D' I; Q, [/ T% {, ?
– Stable emission and noise behavior throughout the vehicle life' c Z; T# q: z5 o' {* R
– Simpler, reliable, and cost effective electronic design with optimal0 C0 Y: }, g z+ M) N. `8 Q
control of multiple injections3 z/ D5 R2 {9 y/ N* F
– Flexible modular pump designed for up to 2000 bar capability with& J6 S w9 e1 m
key focus on robustness and durability .
7 |) v @) I; I; Y! A5 X– Complete pump family supporting various packaging and drive! d8 ?; Y4 T, A0 S5 |: ~
mechanism
/ @: `: d, S* P' s6 m2 m– Compact and flexible design, providing ease of packaging and
4 }7 M- ]6 W& Q, W- j; zsupporting various packaging and drive mechanism: w- o. J6 y! G: r2 u" z! x
– System meets current emissions legislation and evolutions will be1 W) Z) `* }& }% O5 K& ~, r( T0 {
capable of future standards! J r/ b6 y. B5 t
– Full EMS range available including linear oxygen sensor (OSL),
% u. ?. P! f$ P3 ~: Csensors meter recirculation diesel( Q' ^ ^& [; P9 i, f
Property of Delphi Date: March, 2007 28 F( H3 z! }. v4 ]4 i8 M# z7 C
engine sensors, probe air meter, exhaust gas recirculation, electronic throttle, and aftertreatment
4 T) c+ [$ `( H' p– Global manufacturing and engineering footprint0 \ `8 w% O3 r3 z( ^
德尔福Multec® 柴油共轨系统
7 G _7 [; N7 X0 ] N- 性价比最优的燃油喷射系统8 v8 s9 A7 K4 J
• 功能2 _$ b- x' e; t7 I, C/ o' n
– 简单却精确的燃油喷射控制,来自共轨系统快速响应电磁阀9 g) B2 t. d4 O, M" N9 s- u
– 喷油器随应用要求不同而灵活可调
) Z: |- v% c9 g1 Q% G! G1 p; U: S( W– 高压油泵模件化设计1 W u/ ^4 N: X G
– 发动机管理系统由先进的系统策略组成,这些系统策略包括5 O" B' b) f( m, |
APC (预喷量控制)与I3C(单个喷油器的喷油特性修正)等。6 M% d2 o. @" e! @: w
– 低电压运行
% j0 r6 W0 C- D# f* P+ m/ Y, W• 德尔福的优势( ^4 [" x. _* c! R
– 响应绝对快速,性能媲美伺服式压电晶体喷油器1 v$ O4 u# e" {8 | _, Y/ Z
– 在汽车的整个使用生命中,排放与噪声始终保持稳定4 a. w, N: O3 I: j7 }' q
– 更简单、更可靠、更超值的设计,多次喷射控制更加精确) E5 g$ p7 Y i/ X$ L! @8 W4 ~, r1 C
– 灵活的模块式高压油泵,供油压力高达2000bar, 特别注重可靠( Y+ m5 Z0 Q. w: `
性及耐久性0 m, C6 {, j. ^
– 油泵系列完整,可供选用于不同的安装及驱动场合
7 s+ r4 J! t+ H" S! b. n! I- ^– 紧凑而灵活的设计,安装及驱动灵活方便; Y4 _2 g& s8 r. F% }
– 系统满足目前排放法规的同时,其升级产品也将满足更高的法规
8 |3 [$ @" p, D+ _ H1 l8 j要求
' K6 r1 o. p- ?& Y+ T3 ]– 发动机管理系统零部件种类齐全,包括氧传感器、发动机各种传( a$ W7 u/ T9 k% k
感器、空气流量传感器、EGR、电控进气阀以及后处理部件等: j6 Q$ i9 ]& C
等4 W4 q' `: z* Y
Property of Delphi Date: March, 2007 38 D! k9 v4 r0 y! ~: R
– 全球化的生产与工程支持 |
