高手必备,专业主板词汇, p4 y: z" m6 z3 `! u, v1 `* C) U
ADIMM(advanced Dual In-line Memory Modules,进阶双重内嵌式记忆体模组)
6 N& H0 c+ B$ K o) r4 PAMR(Audio/Modem Riser;音效/数据机主电脑板附加直立插卡)
2 P/ c( J& O: j0 w, cAHA(Accelerated Hub Architecture,加速中心架构)$ g/ T' t: ]$ G' T
ASK IR(Amplitude Shift Keyed Infra-Red,长波形抽取式输入红外线)& X8 n1 w+ k% H; y1 L
ATX: AT Extend(延伸型AT); h8 `6 G* u% z2 ~' ?
BIOS(Basic Input/Output System,基本输入/输出系统)3 E7 n0 a! D/ [& m' F8 F
CSE(Configuration Space Enable,可分配空间); g* [# B, |# q) D( |
DB: Device Bay,装置插架
: X( Q9 d6 Y; B7 ]: zDMI(Desktop Management Interface,桌面管理接口)
- n5 z5 X7 n- J+ k3 w" ^4 \* lEB(Expansion Bus,延伸汇流排)
5 q% b$ d1 o t. m' Y. `+ SEISA(Enhanced Industry Standard Architecture,增强形工业标准架构)' ^% @" ^. u$ h3 X! Z
EMI(Electromagnetic Interference,电磁干扰)
$ y1 d) J n# P ?ESCD(Extended System Configuration Data,可延伸系统组态资料)
9 u/ o( J& A9 r1 d( CFBC(Frame Buffer Cache,画面缓冲快取)
* P9 J3 ]# G$ x+ T- i2 WFireWire(火线,即IEEE1394标准)
3 k2 k v$ p6 u, x* k* W5 ^FSB: Front Side Bus,前置汇流排,即外部汇流排
: g$ x1 \# H' r3 eFWH( Firmware Hub,固件中心)
; w& O5 T. n& w n+ L4 b$ VGMCH(Graphics & Memory Controller Hub,图形和记忆体控制中心)1 V4 e6 o3 F7 N3 b1 m: A* `4 U% I
GPIs(General Purpose Inputs,普通动作输入)
' E5 ?3 z* h) I6 tICH(Input/Output Controller Hub,输入/输出控制中心)1 J$ x. w! O# s4 E) P# L
IR(infrared ray,红外线)/ X1 i* I- G W
IrDA(infrared ray,红外线通信接口可进行局域网存取和档案共享)3 _2 c' {" x2 U. F& P* ]. O
ISA: Industry Standard Architecture,工业标准架构* l: F# B$ D- M5 _5 C
ISA(instruction set architecture,工业设定架构)
# \/ ~" J ?& I- gMDC(Mobile Daughter Card,移动式子卡)$ `1 H: I% J! a
MRH-R(Memory Repeater Hub,记忆体资料处理中心)
q8 b ?8 R+ d! H6 h7 qMRH-S(SDRAM Repeater Hub,SDRAM资料处理中心)
& j6 }3 d; p1 Y ]" dMTH(Memory Transfer Hub,记忆体转换中心)
# g6 {' C8 X/ [% ^NGIO(Next Generation Input/Output,新一代输入/输出标准)
5 K- R: N: X; h4 v0 EP64H(64-bit PCI Controller Hub,64位PCI控制中心)
& v: p& c3 G4 n+ `9 y9 ZPCB(printed circuit board,印刷电路板)
, U2 y: w0 D" G: G2 M5 fPCBA(Printed Circuit Board Assembly,印刷电路板装配)
; G- d* T9 ?* F4 qPCI: Peripheral Component Interconnect,互连外围装置9 c5 w4 ]$ D2 s
PCI SIG(Peripheral Component Interconnect Special Interest Group,互连外围装置专业群组)
7 l/ a4 D6 {: T. F% v" z+ LPOST(Power On Self Test,加电自测试)
6 C+ e. B! P" y0 Y; uRNG(Random number Generator,随机数字发生器)$ s3 n- m, Y1 @* |' c% J! I! m6 t2 W
RTC: Real Time Clock(实时时钟)& ~) R7 j( k! j ]! I$ r
KBC(KeyBroad Control,键盘控制器)
1 V' Z1 }3 `$ ~SAP(Sideband Address Port,边带寻址连接埠)( F! V# b* Q. T/ B
SBA(Side Band Addressing,边带寻址)6 g9 j; M1 u* _% g: X* a
SMA: Share Memory Architecture,共享记忆体结构
! I4 g& O) w; n" R$ W( {9 e( M eSTD(Suspend To Disk,磁碟唤醒)6 G! c0 Q, r% N& U p. Y. s; K1 A, v
STR(Suspend To RAM,记忆体唤醒)
) w1 W. x- _7 q' Y- cSVR: Switching Voltage Regulator(交换式电压调节)3 R: {! c/ {& I8 Y! @: F. S6 C! q
USB(Universal Serial Bus,通用序列汇流排)
: Q( \; k) g5 E: u- b# C/ D) hUSDM(Unified System Diagnostic Manager,统一系统监测管理器)
+ `7 Y4 M2 }$ ]- |; D: R: V1 @/ {8 |VID(Voltage Identification Definition,电压识别认证)
& U1 c3 z( U7 \% LVRM (Voltage Regulator Module,电压调整模组)
$ J. y8 @# g) x9 ~ZIF: Zero Insertion Force, 零插力8 O% J6 V! \7 N2 q- M3 a. s! \/ R7 W
主板技术8 k4 O+ N) M+ ?) C( \) {5 C, Q
Gigabyte
% \( R' l2 V: h8 ]; |ACOPS: Automatic CPU OverHeat Prevention System(CPU过热****系统)8 p1 a2 I$ n1 F% j2 u
SIV: System Information Viewer(系统讯息观察)
3 ?1 @. J! @0 R! v4 {4 t磐英0 q" d. C) ?7 e' w
ESDJ(Easy Setting Dual Jumper,简化CPU双重跳线法)" C3 y+ w2 a3 f, g, f: f
浩鑫
1 J B; j6 V8 s# ]* Z. yUPT(USB、PANEL、LINK、TV-OUT四重接口)1 l; [) r4 ^' k3 J' Y
晶片群组
( B! p: Q6 l2 z [4 s6 p( W/ ]ACPI(Advanced Configuration and Power Interface,先进设定和电源管理)7 @3 Y4 A+ l& u b( f7 k4 L
AGP(Accelerated Graphics Port,图形加速接口)
' H- W/ [0 k5 j5 BI/O(Input/Output,输入/输出)
* ]& C8 r2 n1 }$ W/ V0 o8 HMIOC: Memory and I/O Bridge Controller,记忆体和I/O桥控制器" E0 Y0 j p/ ^. }* Q5 a
NBC: North Bridge Chip(北桥晶片)) @4 f1 {- ]+ [( y7 J$ K+ a
PIIX: PCI ISA/IDE Accelerator(加速器)( C B3 a9 [, A" g( P0 h( a
PSE36: Page Size Extension 36-bit,36位页面尺寸延伸模式
1 G. ^& y3 O- M' ~2 hPXB: PCI Expander Bridge,PCI增强桥6 s8 l* K4 \: h( l7 i3 G
RCG: RAS/CAS Generator,RAS/CAS发生器* `7 l$ h- }6 X2 _
SBC: South Bridge Chip(南桥晶片)
. h: n% \$ ? l/ F% ]! e+ CSMB: System Management Bus(全系统管理汇流排)
3 P" d4 |! U4 f: C8 ^! z( sSPD(Serial Presence Detect,记忆体内定序号检验装置)
9 v2 W1 C% D7 }9 [SSB: Super South Bridge,超级南桥晶片
, T& W0 r& Y- J5 e: Q) XTDP: Triton Data Path(资料路径)
; [5 P- B% h' c# O# ?! ?) sTSC: Triton System Controller(系统控制器)
9 d7 O9 i% b/ _' W. f8 zQPA: Quad Port Acceleration(四接口加速)4 V9 E$ T! K9 t- j* Z+ H, k
