11天前
查看: 2322|回复: 13
[求助] 人世间最痛苦的事莫过于蓝屏!help me!
发表于 2009-11-10 10:41:11 | 显示全部楼层 |阅读模式 来自: 中国福建厦门
       起因:组装台式机从客厅搬到房间
3 n$ g% q, u  B$ j* D( \' G - {$ c' y1 u2 g! M( B
出现问题:启动时进入windows xp滚动画面而且滚动条滚玩出现欢迎使用后又从头开始启动
7 T9 ?+ d9 v0 }  U% |$ C# { $ K: G- c& l/ S& ^
                 而且可以顺利启动!这种情况大概10次开机有6-7次会出此情况而且都是插上电源: j0 z( T$ }1 b' G: m6 c" @
  $ ?2 E7 Q5 h4 Q! H
                 第一次开机时,之后重启什么的都很顺利!7 t  n5 T6 T3 x% v2 n
& T5 w, v& k7 h$ h) X2 b$ z8 I' l                 由于总这样有点不爽于是显卡、内存、硬盘我都有拔下来擦过再插上!但没有效果涛声依旧!0 s/ `/ n6 H3 J6 K
  o8 J9 r" q8 r  ^                 逼不得已重装系统(ghost版本xp)上述问题不会发生了但又出新问题---启动时蓝屏!
, j( M0 j. V! _3 k# X
/ ~$ o+ E3 V' r                 而且同上面情况一样进入windows xp滚动画面而且滚动条滚玩后就出现蓝屏--重启还是可以顺利启动. E( W. C# k. U. t/ u1 n
4 S4 N4 j3 {+ i; i- C                 现在每天回去第一次开机就如上所述蓝屏,但后面重启什么的也都还ok!% b: f1 x! i) X9 |: U. z2 }
% x( G1 H& U  O! f7 x
下面是有一天的蓝屏信息(昨天代码是0x00000050)
  q+ z* }# E9 @% |+ aa problem has been detected and widows has been shut down to prevent damage to % w# ~$ o# v7 w% d$ m1 E
you computer.
. ~4 y1 k3 M/ `5 q. V, girql_not_less_or_equal6 [& R2 J% B& M* d' A
if this is the first time you've seen this stop error screen,restart your computer.
# f4 i# L( ~& a- x8 |if this screen appears again,follow these steps:
( D: l9 s) o; o' o. Y" V4 ^% Fcheck to make sure any new hardware or software is properly installed.
4 ?8 w& v* F3 d1 bif this is a new installation,ask your hardware or software manufacturer; ~, t+ Q/ v& F. f
for any windows updates you might need,
9 \# H- G, O9 V. P
if problems continue,disable or remove any newly installed harddware or software.
4 e( h& `( o& U; i7 x9 u. Udisable bios memory options such as caching or shadowing.
( t! ^" Z7 J( q! \9 D' \if you need to use safe mode to remove or disable components,restart your! a4 o! T. y: |% s9 N# j2 d" I. Y
computer,press f8 to select advanced startup options,and then select safe mode.
: l( {/ d1 c- t5 N7 ctechnical information:
3 W/ E( D  y+ o! B( s8 @' B***stop:0x0000000A(0X0007B000,0X00000002,0X00000001,0X80520649)
& W- {$ h# y; w( [# N- O
* {" E3 E5 V# b$ m4 M7 S$ K) I
& X+ m' i2 p" H0 m请各位兄弟姐妹仁者见、仁智者见、智集思广益给出点主意
) D2 t" F1 T! ]1 n- w : m9 N3 s& S8 G' W" X
我天天看着那个蓝屏心里堵得慌!拜托大伙儿了!先谢了!
发表于 2009-11-10 11:24:31 | 显示全部楼层 来自: 中国北京
1、换个不是ghost的系统
# q+ L8 q5 b- y9 R: Z4 \! Y2、如果是两条内存,每次只插一条,每个插槽轮流试一下,分别启动,目的是排除是不是内存问题或某条插槽有问题。7 W7 w1 y& b' g3 q6 O
3 `# S0 b/ J6 \9 n
这两个可能最大一些
发表于 2009-11-10 11:26:31 | 显示全部楼层 来自: 中国山东烟台
换个版本的系统重新装一下试试吧:time:
发表于 2009-11-10 11:43:36 | 显示全部楼层 来自: 中国广东广州
重装系统,以前也有过$ y8 @# m5 u5 Q' E; n, V, q
一位是内存坏了
, i3 C2 u8 j4 q结果DELL 工程师帮我把电脑的主板,内存全换了还是没有0 K4 b6 E) s  o4 R- P3 O. {* L
重装就好了
发表于 2009-11-10 12:37:07 | 显示全部楼层 来自: 中国江苏苏州
 楼主| 发表于 2009-11-10 14:18:52 | 显示全部楼层 来自: 中国福建厦门
回复 2# h56kps 的帖子
我还真是两条内存!原来配的时候只有一条512今年上半年从一个同事那里搞了一个512
4 `8 c# J6 I  A/ ^; p3 d: \; A) T$ m- z) x3 H7 x+ o) P
变成两条内存都是ddr2的但牌子不一样还是有点小区别不过已运行半年没出过什么事!
 楼主| 发表于 2009-11-10 14:20:12 | 显示全部楼层 来自: 中国福建厦门
原帖由 angelrain_gu 于 2009-11-10 11:43 发表 http://www.3dportal.cn/discuz/images/common/back.gif# L. L9 H7 {) K( o
重装系统,以前也有过
( V. u* h5 R  c. U8 L* X4 v一位是内存坏了3 d3 Z6 L* y$ d7 d' v& ]: M
结果DELL 工程师帮我把电脑的主板,内存全换了还是没有9 j7 J; L) ~0 L3 Q
重装就好了
* ]0 Q' N7 G; Q) X8 X* v. t. C( ~* C# d# v
--------------------------------------------------------------------------------# W$ y: b9 W) s% b  `
我装了三次了!不过都是ghost版本的!
发表于 2009-11-10 14:54:11 | 显示全部楼层 来自: 中国浙江台州
是硬件问题 驱动不正常 那种ghost版本的很容易出现这种现象
发表于 2009-11-10 15:59:57 | 显示全部楼层 来自: 中国安徽芜湖
肯定是设备的问题,最好把机箱打开,把所有的硬件拔插一次。
  z, ?; |( M/ {根据你说的情况,可能是搬动电脑时,灰尘掉入什么地方所至。
发表于 2009-11-10 18:34:53 | 显示全部楼层 来自: 中国安徽合肥
建议重装系统,最好使用原版的主板驱动和显卡驱动
发表于 2009-11-10 19:17:47 | 显示全部楼层 来自: 中国台湾
應該是ram的問題 附上籃屏解讀器5 O8 u5 n9 |- K; W
9 t$ ^$ ]; x2 {' n$ O# q[ 本帖最后由 nba222 于 2009-11-10 19:20 编辑 ]
WINDOWS藍色當機畫面解讀.rar
76.65 KB, 下载次数: 15
发表于 2009-11-12 14:52:29 | 显示全部楼层 来自: 中国北京
发表于 2009-11-12 16:30:46 | 显示全部楼层 来自: 中国云南红河哈尼族彝族自治州
我觉得问题还是在内存上面,尽可能用同一品牌的内存条。
 楼主| 发表于 2009-11-21 10:33:21 | 显示全部楼层 来自: 中国福建厦门
感谢各位兄弟出谋划策!问题已经解决!
! T& W3 R) y9 g) S$ S* U! G( J( |4 m5 T2 Z
后来弄了一正版xp装了----蓝屏是不会了但第一次开机老是重复启动!2 q9 ?( \: X# U
/ q( l8 E) \% Q
后来最终解决之道是-----拔掉一根内存(我两内存厂家不一样一条是捡别人的但都是ddr2 533)
7 v2 r+ x1 c: T0 N; _' G6 \, {
9 W7 y) h1 A0 g/ S有点郁闷的是用了半年没问题怎么这会儿就出毛病了?
$ S3 Q! ]1 j* @0 @7 E9 k% C1 p. I* Z1 b" h6 u6 l! p& X
问题总算解决了----再次甘感谢大伙儿!
