标题: 面积求和及长度求和的LISP [打印本页]
作者: 唐昕晨    时间: 2008-2-1 17:04
标题: 面积求和及长度求和的LISP
关于对于面积求和和长度求和,还是有很多用途,在这里写一个lisp程序。0 a8 a: h" y( O! Z  n
加载程序,在命令行运行am% x, F) A$ a: C; F3 N+ ~* {: T
+ F& m& a. u" r  i1 C0 Y选择你要求和的物体,可以是line ,circle,arc ,ellipse ,spline, polyline,mline等,算出面积和长度。
3 x: B. }+ U% X( s# i: h+ u, o , k, m+ E% ~3 L7 N
指定位置和高度,就可以用文字标注出来。
1 i2 d% W& @! e# `
, o6 }7 C. k7 w! l. w 0 O* w6 x9 c; G% K" h
(defun C:am (/ ss l i totalarea ename obj entarea)
) p4 m8 w0 q. W4 V, }" ]  (if (setq ss (ssget))
& @! A. Q  f% z3 W' E1 O    (progn
) ?! g  `; J7 J* x% f# F1 Q      (vl-load-com)
9 @8 b! e7 c) i8 X9 T2 l# D      (setq modelspace (vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object))))
" _. m* |) ^) J! h- |, D9 i      (setq l (sslength ss) i 0 totalarea 0 totlength 0)( o* a1 G5 b" Z, w) w
      (repeat l) f! q% @" p* F
        (setq ename (ssname ss i))
2 L6 x3 L& w0 @! ?& D4 W+ z6 C        (setq obj (vlax-ename->vla-object ename))2 n9 H$ F3 B) \# J9 |% z) D
;;(vlax-dump-object obj T)
+ [! C9 ]4 L( k* ]3 z (if (vlax-property-available-p obj "area")
) p! ~4 X) @+ e: P9 K& o3 i5 b          (setq totalarea (+ (vlax-get-property obj 'area) totalarea))# \! J4 W7 g, |) L: U8 G8 Q& s/ S$ x
        ): h+ W& h# h6 v  J) T, K, l/ O
(if (= (cdr (assoc 0 (entget ename))) "MLINE")
2 N/ {" n# {( O' G$ L" r( B; H( {) N+ T3 B   (setq totlength (+ totlength (ml-length ename))), W  Z8 C3 N' V3 G* T/ A
   (setq totlength (+ totlength (vlax-curve-getdistatparam ename (vlax-curve-getendparam ename))))7 ?, g( Z, z7 Z/ g4 S0 o
)0 O: p: T- l, A2 B4 {0 X
        (setq i (1+ i))7 [! A) E/ S  y7 |# ^
      )$ Y% B8 m9 {7 Y4 D( b& B( I# [
      (setq text1 (strcat "总面积为: " (rtos totalarea 2 4) "平方毫米")# ^( L: g( q/ ^; i- U4 Y0 I1 t
     text2 (strcat "总长度为: " (rtos totlength 2 4) "毫米")
" L0 _/ }7 R. O' t4 \      )' f- Y+ ?" d- X+ i; s) x
      (if (setq insertpt (getpoint "\n请输入文字插入点: "))
9 b3 t5 D6 H3 ^9 K# {- h (if (setq height (getdist "\n请输入文字高度:"))4 M2 a  ?5 [1 ]
   (setq insertp1 (vlax-3d-point insertpt)$ c% w; ?3 Z+ Z$ u) I8 Y. e
  insertp2 (vlax-3d-point (polar insertpt (* 1.5 Pi) (* 1.5 height)))1 t2 g; W" F: h, D
         textobj1 (vla-addtext modelspace text1 insertp1 height)
; ^# s* _% s9 j  textobj2 (vla-addtext modelspace text2 insertp2 height)6 n) r  _3 t& L
+ o+ J5 o& D+ I4 s% u( j' I )
  p+ Z! G8 q! _! {$ r( O      )
; Y. Z( _+ L2 u1 p    )6 U4 }/ P) s" d/ p3 U# ^
  )6 m, Q$ Q' R6 V
)+ J. @5 V% w! o( {+ }2 ~* i
(defun ml-length (ename / j d ptlist)) H; ^" m7 D" z% ^9 E
  (foreach n (entget ename)
4 o) S) b- X9 ~    (if (= (car n) 11)$ J( J$ x( Y1 a4 l6 Y+ g
      (setq ptlist (cons (cdr n) ptlist))
2 X7 k; S$ D3 o& v/ o' }) T    )
$ O8 J! d* s4 m  )
! K3 z3 y( F7 K/ b  (reverse ptlist). W: w8 m/ X1 L0 }1 y/ e% g2 H
  (setq j 0 d 0)
% [# h" @' k, t, k: i- R; |$ }6 w/ R  (repeat (1- (length ptlist))  ]' }9 q3 @0 N9 E9 b% G
    (setq d (+ d (distance (nth j ptlist) (nth (1+ j) ptlist))))
) g, l) Z& a( n% X  E- w) A    (setq j (1+ j))
/ N% |* [! n& e) C( V3 }  )! Z5 m( u; F2 k
  d' Q( S7 Z# A2 p, i# _
作者: leizl    时间: 2008-2-2 09:28
用了一下,为什么会出现"总面积为: 0平方毫米"
作者: leizl    时间: 2008-2-2 09:31
图中画的是10X10的方形.
作者: 唐昕晨    时间: 2008-2-2 15:11
原帖由 leizl 于 2008-2-2 09:31 发表 http://www.3dportal.cn/discuz/images/common/back.gif8 `+ ^! ?! i1 z% _
图中画的是10X10的方形.
+ ]" u' A5 h3 L6 n
+ D' j; c7 K2 T' B6 M
因为求面积的对象必需是封闭的多段线,,矩型,圆,封闭的样式条线,.如果是单纯的封闭直线,那么是不能查出结果的.
. x+ H2 }# J/ J  W6 o) L& ]; V( c4 O
这时你就得把直线用PE命令合并起来后再求.
作者: wsw123    时间: 2008-6-26 10:23
怎么把求出的面积标住到图上???
作者: myis1982    时间: 2008-6-30 17:02
是个很实用的方法,谢谢楼主!!
作者: 一粒色    时间: 2008-10-16 22:31
感谢楼主,再发多些好的工具。
