标题: 西门子发布Solid Edge ST3的最新补丁MP3 [打印本页]
作者: 3DST明明白白    时间: 2011-3-8 08:07
Dear Solid Edge Customer:
, H& ~' \  d/ g: x% K2 z
We are pleased to inform you that Maintenance Pack 3 (MP3) for Solid Edge ST3 is now available for download on the GTAC FTP server.
# H" d  }/ y2 k2 O% A
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
* S9 y' Z! Q! D0 O0 o* `( E+ M7 u
Sincerely,
. I- P7 V, A- U
The Solid Edge Team
; P' W0 S# u  I8 @$ m3 x1 D
  U* W3 H3 c$ l
Download Location:
" ]9 J7 R+ ~3 A2 Z: d! }& u7 ~
! L# k; {& Q4 @
Solid Edge (Maintenance Pack)
* R: S- |, v# B5 v9 [8 ]
http://ftp.ugs.com/solid_edge/ST3/SolidEdge/
+ r, C0 W; }7 r* i6 Z8 w5 Y
Solid Edge Insight Connect (Maintenance Pack)
* m: U$ @. B- o
http://ftp.ugs.com/solid_edge/ST3/InsightConnect/
( U  B+ E; U5 P6 v0 F% k0 N1 t8 |
Solid Edge Viewer (Maintenance Pack)
0 Z+ B, S4 F0 z: h9 _! }
http://ftp.ugs.com/solid_edge/ST3/SEViewer/
- r, r1 m) ]: i6 M
Solid Edge Mold Tooling (Maintenance Pack)
0 C3 {+ D" b5 p
http://ftp.ugs.com/solid_edge/ST3/MoldTooling/
- I; @. a2 w/ R; @2 d3 N
Solid Edge Insight Server WSS 3.0 (Maintenance Pack)
. m7 |; F9 A# J  C* H$ d) w
http://ftp.ugs.com/solid_edge/ST3/InsightServerWss3/
. f5 ]* N1 U( b
Solid Edge Insight Server SharePoint Foundation 2010 (Maintenance Pack)
2 C- }4 r% K" F7 ?4 k& \( b
http://ftp.ugs.com/solid_edge/ST3/InsightServerSharePointFoundation2010/
: p- ^) W" V: V0 v7 D/ ?
Solid Edge Embedded Client (Maintenance Pack)
! h0 Z, e4 Q( y! K" m. a6 a
http://ftp.ugs.com/solid_edge/ST3/SEEmbeddedClient/
% _* V: ^3 l9 ]3 X
Solid Edge Embedded Client Structure Editor (Maintenance Pack)
, b6 N" C$ `' @) I
http://ftp.ugs.com/solid_edge/ST3/SEECStructureEditor/
6 J2 ]7 c& P4 q/ \6 ~, E9 ]
Solid Edge Embedded Client Administrator (full install)
( h; {4 V  O2 X0 U5 Q& R4 a2 n
http://ftp.ugs.com/solid_edge/ST3/SEECAdministrator/
% C& u" B: E! L2 n) s4 q& g3 n! s
+ j/ e. {) C/ J  b/ Z
Installation:
1 F# {( i6 @& B: v+ m6 E) \9 {+ @- |2 ^
+ h& P6 T8 F; Z1 E' i0 ^
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
  b. f' \! e5 T. A
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation.
$ y0 M; {# t4 l( ]* Q
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
: p9 u7 I! G: W2 A# J
- v9 f/ `6 K- H8 Q$ }) t
E-mail Notification:
* Q+ z" p0 @- H& b
" x2 _5 p" C; X# N" ^% ]* \
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
; ~7 s+ a. `2 t( n
2 t# \9 j+ \7 r( X' ?
This Maintenance Pack addresses the following PRs:
" x! J0 o- E! ~  r9 G1 D
: `# j9 A% c/ _
===API===
  Z6 k7 |  z# V9 ^
PR 6426380: Not getting Colors in SEPartReader, SEReader
* Q* ]- T7 e; u4 P
===Assembly===
1 C- T% b$ f) l1 x
PR 1824462: Fixed crashes identified by crashlog files
2 t8 j7 O8 U) t- W
PR 1826468: Path name length is limited to 129 characters in Property Manager
8 T9 s; o, p. |
PR 6462576: Solid Edge crashes after selecting part of SysLib after placing it
0 U. Q0 a/ k' r
PR 6465652: Abort if save is clicked while config file open dialog is active
5 M6 @( W# W, E2 r, }$ T2 ?
PR 1829176: Unable to activate zones with double-click
, m7 U* p- L; {! @3 @
PR 6471148: Display performance is slow on rotations and zooming
2 Q6 j: e4 i# v5 Q
PR 6474039: Fixed crashes identified by crashlog files
5 g; c# n2 j- B! l1 P) W$ e. e) t
PR 1815765: Unable to open Catia V5 R20 part files
! k- D" {9 j$ E  d$ x8 T; @( G
PR 1828742: Solid Edge Frame Design / Routing API.
6 h; _; A# f3 r6 o
PR 6417945: the default location of the Quickbar / Assembly Pathfinder is not correct in Sketch
" u" P9 R, F; A% y
PR 6429834: Patterned frame members list is on separate line item in Parts List
" \& H9 e! u- T/ K* V# T4 }* Z; A
PR 6461646: scroll to part results being obscured by the relation tree
' O# v4 g7 a  U9 {& I8 i' s. X
PR 6470893: Solid Edge is slow to open a Parasolid assembly
5 Z, s9 ?, y+ q' ~  p2 y8 c
PR 1819591: Assembly aborts when creating relationships
) G2 {" \( k; H3 v7 t
PR 6469074: Assembly reports are not picking up custom property values
2 A, ^/ J% m4 d9 @
PR 6472642:  New Menu Starting Wrong Template
$ M) F9 k  c* ~7 O/ R8 ?. L. c3 w
===Draft===
+ j- f2 H0 t1 d/ u
PR 6327121: Abort on close if dim tracker has been run and something remained in the select set
$ a: p' X, w- X0 @8 D+ C. W: `
PR 6357213: Callout Text gets merged if Alignment is changed to Center or Right
) [, J7 _9 d7 i; @! ]- B
PR 6412216: Dimensions detach on update
& z; I" u3 s# q$ W. `( `# ?
PR 6427966: Part aborts revolving a synchronous cutout
2 Y0 C5 {) s  x% A5 y: Y
PR 6429679: Exiting profile causes an abort
$ {* k' `  n, P& @
PR 6454096: Cannot exit edit boundary environment after ctrl-drag of 2d object
" l: x/ L; f, w$ B0 O8 Z/ a8 G
PR 6456030: Solid Edge open DWG Options/Review are not giving the correct sheet information
. E; v) g4 y9 D
PR 6456838: Can't place a dimension in a Detail View using dimension axis
5 i: g6 P7 m5 Y" i( i% }3 \! l
PR 6464949: Parts list moves up and left by .175 mm when opened
7 [2 h* ?+ e' n
PR 1816750: Cannot select elliptical arcs in hole table command
8 ^, t5 R7 @0 i/ P: B
PR 2162210: "Thread Display Mode" changes value when Apply button is clicked on other property pages
0 c7 ]' x  q+ i! z' c, ~6 ?( U
===Insight/View & Markup===
7 L% N2 z8 F5 f8 u, x
PR 6457292: Failed to generate document libraries property mapping information
4 X: }% s- l! M9 ~
PR 6465929: Insight server log files cannot be generated for SharePoint 2010
8 h3 N! [1 {8 B9 \& M
PR 6466137: Registry key VMOnSaveEmbedViewingLink not delivered in ST 3
# S' ~/ i9 R  t6 L* K& g
===Part/Profile/Sheet Metal===
4 v* A# U/ y. S
PR 1776878: Callout for %HS is incorrect on Part Copies
2 `! E! E' Z( o3 p
PR 1824462: a crash that may occur when imprinting curves
. n: ~, }* J, W  t5 {$ P
PR 6367518: If Relationship Colors is on, no indication when dimensions are failed
: K  a  k, G- i( A" p3 {/ A
PR 6434556: a crash occurring when locating items in pathfinder after closing a file
" o, p  n8 d, b: Y9 ^- s" W" d
PR 6453116: Immediately after rotate you see a flash of the model in a different orientation
" i& k- W6 P+ b0 t& R+ K
PR 6456053: Sync Hole gets deleted if it’s used sketch is deleted after a Move to Sync
* x+ E  ~! j/ E+ X1 U$ l6 q/ P
PR 6467561: the Solid Edge process hangs around after selecting a region then exiting
3 g: b% p1 F% f% T( n! m7 u, E
PR 6468272: Unable to edit a dimension value with a key-in after scrolling with mouse wheel
* C+ v! n- g4 E& m) U
PR 1809044: a crash is occurring when trying to open a Solid Edge file
* K2 q, y+ {9 R. B
PR 6471224: the concentric live rules turning red when using local symmetry option
0 F& W; ?" H3 y* L
PR 6471336: Dimension display disappears during edit formula
, ~" l  t3 ]; H6 _
PR 6473059: sync move appearing sluggish on keypoint locate
) f+ ~/ G; w5 Q$ Q+ Y% x
PR 6474371: Cannot pattern a hem
% e8 s% D3 ^! J& t6 ~/ \8 y
PR 6475818: Send Mail & Crashlog tracking failing under Lotus Notes
! C; x& K* j' e* g" K; U
PR 1827775: Displaying the FOP table takes a long time
  G4 A- b+ v7 V( N$ Y0 N' W
PR 2163514: "Show Only Overridden Variables" of the family of parts not being displayed
4 o% E) S2 H% ^- F- F2 |" a: ~. Y3 N0 m
PR 6477746: Cylinder from a Lofted Flange in ordered sheet metal part has incorrect flat result
作者: 368天    时间: 2011-3-8 08:32
不明白别的补丁和Solid Edge (Maintenance Pack)http://ftp.ugs.com/solid_edge/ST3/SolidEdge/
; }1 U. }; t  G; L& }; `7 \; u/ U) {+ o! p( g
这个补丁是啥关系?
作者: 308408    时间: 2011-3-8 12:47
比较关心升级了mp3后,原来的破解还能用不了
作者: 368天    时间: 2011-3-8 12:53
% }# j, Z. f) p0 u' E308408 发表于 2011-3-8 12:47 http://www.3dportal.cn/discuz/images/common/back.gif
' N- Y$ k9 f  f可以用
